Home › Forums › Products › Rackmount › H9000 wordclock THRU? › Reply To: H9000 wordclock THRU?
January 19, 2026 at 3:11 pm
#194319
Ok, I’m still not sure why that wasn’t working for you.
I’ve setup the H9000 as a Wordclock THRU device before and it worked.
Note that you can also clock the H9000 via ADAT so you may not even need to have it hooked up to your WC chain. It will clock to your interface via the ADAT connection.
