Home Forums Products Stompboxes H90 + overdrive Reply To: H90 + overdrive
#194959
swatmark
    I think it’s a routing problem.
    1/2 are your main stereo in/outs, and it looks like they’re getting mixed up with 3/4 when I trace through that diagram.
    If you look at the System input/output menu, you’ll see 1/2 as a stereo pair, and it will automatically handle mono or stereo from those connections.
    3 and 4 are two isolated ins and outs, but they can be used as a left-right stereo insert loop if you match up 3to3 in/out and 4to4 in/out.
    So your main stereo input and stereo output are best done on 1/2, and your FX loop via 3/4.
    That should help, I think.
