Home › Forums › Products › Stompboxes › Crush Station algorithm very low volume › Reply To: Crush Station algorithm very low volume
March 25, 2026 at 11:52 pm
#194997
<span style=”font-size: inherit;”>I tried to edit my original post, but for some reason it won’t save so here is some more info about my issue …</span>
When I first enact any of the default CrushStation or Sculpt patches (or any custom ones I make with those algos), the volume is normal for about a millisecond then it drops. Also, if I lower the mix to 0 on any patch, the volume is normal, but as I start to increase the mix, the volume drops more and more. This happens regardless of parameter or preset. I’ve tried every setting I could and with/without the noise gate enacted.
