Home Forums Products Stompboxes Wish list from users for future updates of the H90 Reply To: Wish list from users for future updates of the H90
#195034
rivera
    I would like to submit a feature request concerning Perform mode with algorithms A and B configured in series.
    In mixer-based routing scenarios, proper gain staging and wet/dry management require dynamic control of the KillDry parameter depending on the active processing path.
    Desired behavior:
    When A = ON and B = ON (series routing), A should operate with KillDry = ON, while B remains KillDry = OFF.
    When A = OFF (bypassed) and B = ON, B should automatically switch to KillDry = ON.
    This effectively implies a conditional dependency between algorithm bypass state and KillDry status, allowing the unit to maintain a consistent wet-only signal path at the mixer level.
    Currently, this requires manual parameter changes or external routing workarounds, which reduces usability in live or hybrid mixing environments.
    Proposed improvement:
    Introduce a conditional or state-linked parameter system, where KillDry can be automatically reassigned based on:
    Algorithm bypass state (A/B)
    Routing configuration (series/parallel)
    Alternatively, allow user-defined parameter linking or logic-based modulation between A and B states.
    This would significantly improve integration of the H90 in professional mixing workflows.
    Regards, Gilles
