Home › Forums › Products › Stompboxes › Lossy in H90 › Reply To: Lossy in H90
There’s no doubt about it. Chase Bliss knows what it’s doing. AFAIK Lossy is well on its way to becoming a classic.
There is an H90 user wish-list thread here. You may want to post your “error effect” thoughts there. Eventide does monitor that thread in particular and they do occasionally implement user-requests posted there.
You mentioned Resonator so I thought you might get a kick out of the attached program. It is Resonator into Glitch. I chose this combination of comb filtering notes because, with this combination, every note you play will resonate (something to do with upper order harmonics, I’m told). I did scramble the sequence of those notes a few different ways so the particular way the notes resonate is different between no-HS, HS1, HS2, and HS3.
Good luck!
~Tony
