Home › Forums › Products › Stompboxes › H90 and H9 U2 delay settings › Reply To: H90 and H9 U2 delay settings
April 1, 2026 at 6:37 pm
#195059
I see you have an H9 available. Assuming you are OK with the programs I posted, that opens up a new option: the full Monty.
You could run U2 WOWOY 2 on your H90 and then run that in series into your H9 where you can run a Shimmer preset based on the one in U2 WOWOY 1. So you’d run Sticky Tape into Vintage Delay into Shimmer. If you do, you should lower the delay levels from 36 down to something like 31. As always, though, adjust to taste.
Good luck!
