Home Forums Products Stompboxes H90 and H9 U2 delay settings Reply To: H90 and H9 U2 delay settings
#195086
apalazzolo
    Update:  You can cancel your E-Bow order.
    I’ve attached three programs I made over a year ago and the long sustaining notes in this song might be the perfect time to use one or more of them.  Please read the developer notes to understand how they work.   There is a little bit of technique to develop.  Most importantly, you need to play a short rest between each note and then sustain each note at least a little bit before releasing it.   This will allow the program to swell in smoothly.
    With the two Singularity programs you can sustain a note forever by releasing and re-picking the note about every quarter note.   When you get the hang of it the note will sustain across each rest so you won’t hear it.  You select different hotswitches for different swell in and sustain times.  Aux switches select various shimmer octaves.
    With UltraSwell + you use the PERFORM KNOB/EXPRESSION PEDAL to determine the swell in and sustain times.   My PERFORM KNOB/EXPRESSION PEDAL are linked together so you may have to change this setting directly to EXPRESSION PEDAL depending on your rig.
    These should give you a lot to work with.  Good Luck!
    PS I only see two of the three attached programs so I’m going to add the third in another post.
