Home › Forums › Products › Stompboxes › H90 not passing audio signal on custom programs › Reply To: H90 not passing audio signal on custom programs
#195202
apalazzolo
    I realize that you specifically said you removed the stereo inserts.   But … failing to remove the stereo inserts is soooo likely to cause no audio to pass, I’d suggest you double check that the inserts have been bypassed or removed.  It’s possible you did that, but forgot to save each program afterward.   It happens.
    By the by, I’ve just remove the inserts from all my programs too.
    Good luck!
