H90 not passing audio signal on custom programs
Home › Forums › Products › Stompboxes › H90 not passing audio signal on custom programs
    • #195201
      TobyEShaw
        I recently changed the signal routing on my H90 from having all the other effects pedals on the board routed through inserts 1 & 2 to just having everything in series. So there is currently no effects pedals in the insert loops. However none of the programs I created now pass audio signal.
        I figured I needed to change the signal routing for those programs in H90 Control by removing the inserts there, which I did. But H90 still doesn’t pass any audio signal on any of the programs I created on that user list.
        If I switch back to user list 1, everything goes back to normal,
        What am I doing wrong? How to I get my custom programs to work properly again? Thanks
      • #195202
        apalazzolo
          I realize that you specifically said you removed the stereo inserts.   But … failing to remove the stereo inserts is soooo likely to cause no audio to pass, I’d suggest you double check that the inserts have been bypassed or removed.  It’s possible you did that, but forgot to save each program afterward.   It happens.
          By the by, I’ve just remove the inserts from all my programs too.
          Good luck!
        • #195208
            If you export a Program or your entire Program list we can take a look at what may be causing the issue.
