Home Forums Products Stompboxes H90 control bug Reply To: H90 control bug
#195315
h90rus
    I’ve spent more time paying attention to this User Preset issue and it seems the copies of existing presets are slightly modified and not accurate copies. Most parameters are set according to the original but a small handful of settings will be different such as tempo synch and mix. Not all saved presets had this occur. I was also careful this time to only save presets from the h90 device, and was always cautioned that I was overwriting an existing preset with the same name.
    Curious if anyone else has observed this issue and knows the source?
    I’m connecting to H90 control using Bluetooth, latest updates and firmwares applied. I tried a factory reset as well just in case there was something corrupted in the user space but encountered the same result.
    Thanks.
