Home Forums Products Stompboxes Help with Space and expression pedal to control input of wet signal Reply To: Help with Space and expression pedal to control input of wet signal
#195333
apalazzolo
    FOR FREE:
    1.  There is a “Feature Request” thread in this forum.  Eventide does review it so that would be the place to request a change.
    2.  You can use DualVerb.
    3.  Have you looked to see if midi can be used to achieve your goal?
    AT MINOR EXPENSE:
    1.   You could sell your Space and upgrade to an H9Max.  They are cheap on the used market.  It will have so many other algorithms, including UltraTap which does exactly what you want.  By the way, I use Factor and H9 algos in my H90 all the time and many have really held their own over the years.  I know some people couldn’t part with all the knobs on the Factor pedals so that might be an issue.
    2.  You could put something with stereo outs before your Space (like a chorus) to create a parallel loop on your board.  That would include a volume pedal and a micro mixer (RJM, Fishman, and others sell them) to link back up with your mono signal chain.
    3.  You mentioned wet/dry mode. I’ve never had a Factor pedal so I’m at a loss, but perhaps you could use that (without adding a stereo chorus pedal) and a micro mixer to get back to a mono signal chain.
    Hope that helps.
