Home Forums Products Stompboxes External Control Access to H90 Perform Mode 2 Please Reply To: External Control Access to H90 Perform Mode 2 Please
#195413
h90rus
    Can’t speak specifically for the wiring of the Strymon 3 button, but the h90 should work fine with a normally open switches connecting:
    tip to sleeve
    ring to sleeve
    tip and ring to sleeve
    assuming the Strymon does this, I would confirm you’ve correctly configured the exp port as a 3 button switch and not an expression pedal per:
    https://cdn.eventideaudio.com/manuals/h90/1.12.5/content/system-menu/io.html
