Home Forums Products Plug-Ins Temperance PRO Reply To: Temperance PRO
#195416
h9controller
    Hey stxmahn,
    Thanks for checking out Temperance Pro.  For the first question, if you’re asking if you can select individual notes to Temper, such as C4 and D6 for instance, no there isn’t a way to do that from the Manual Tab.  They repeat across all octaves and you can use the Temper Range Sliders to move this Tempering window up and down the spectrum.  Using MIDI and disabling Octave Repeat would allow you to accomplish this (via MIDI of course).
    For the second questions, yes you would use the Low and High Cut filters to exclude all reverb to a specific range.  Maybe we could add the ability to enter these ranges in note values in a future update, good suggestion.  As a work around you could move the Range Slider to a specific note, then drag the Low or High Cut filter to the same location and fine tune to taste.
    Hope you’re liking the plug-in.
