Home Forums Products Stompboxes H90 Expression Calibration seems a off Reply To: H90 Expression Calibration seems a off
#195469
unfunfionn
    Hi there,
    I was wondering if there’s been an update on this? I’m still experiencing what I think is the same issue, but it’s not just limited to an expression pedal. The issue is the same with the HotKnobs themselves. In my case, I’m trying to control the Shift parameters in the Polyphony algorithm with either an expression pedal or HotKnob A. No matter what I do, it doesn’t set the correct minimum value. It is always one value too high or too low, i.e. when I want to set it as unison it saves -m2 or +m2 instead. This basically negates everything I’m trying to achieve.
    Best,
    Fionn
