Home Forums Products Stompboxes Blender-type routing – possible? Reply To: Blender-type routing – possible?
#195483
joecozzi
    I can have my dry signal control by pmix (as long as it is under 100). I can have a reverb on a parallel path set at 100% wet (kill dry engaged), and use the mix control as the reverb amount – and the same for the other side (maybe trem… set up kind of like a Flint), or any other effect….
    Yes in every case.
    This is parallel mode, and not dual, correct?
    Let me clarify: H90 has two routing modes – Insert (default) and Dual. Parallel signal paths are possible in both routing modes. The diagram you posted shows Insert Routing mode with a parallel signal path. It’s only in Insert routing mode where you’re allowed to create a stereo effects loop, so stick with Insert mode.
    If each mix is mapped to an encoder…. this alone to me is worth the cost of admission! Blessings, StevieD
    Yes, it is possible to map P Mix, A Mix, B Mix parameters to any of the six possible Quick knob assignments.
