Home › Forums › Products › Stompboxes › Blender-type routing – possible? › Reply To: Blender-type routing – possible?
#195488
Stevied
    Does this setup work if I am only using the H90? Meaning, if a have, say, micropitch as effect A, and tremoloverb as effect B. If I set them in parallel, and select the configuration with the third brach between them, am I essentially creating two parallel effects paths where pmix is the center and each of the parallel paths are set to 100%wet? Using my Xotic blender example, I was seeing if parallel routing like this could be done entirely within the unit.  Each branch set at 100% combined with a  separate dry signal.
