Home › Forums › Products › Stompboxes › Blender-type routing – possible? › Reply To: Blender-type routing – possible?
May 19, 2026 at 9:34 am
#195504
Please give this a try and let us know if this is what you are looking for:
- Load MicroPitch and TremoloVerb, enable Kill Dry for both presets
- Set the routing of the algorithm ins parallel, no need to enable an external insert.
- Set the P Mix to 50%, or whatever you like for your dry value
- You now have 3 level controls:
- P Mix will determine the level of your dry signal
- MicroPitch mix will determine the level of MicroPitch
- TremoloVerb mix will determine the level of TremoloVerb
