Home › Forums › Products › Stompboxes › Bypass/Active › Reply To: Bypass/Active
June 8, 2026 at 4:31 pm
#195707
Which act/byp command have you mapped to a CC#? If you map a CC# to P act/byp, sending a value greater than 64 will toggle the active state. Sending a value less than 64 will have no effect. If, however, you map a CC# to P act/byp (M), sending a value greater than 64 will activate, while a value less than 64 will bypass.
