Bypass/Active
Home › Forums › Products › Stompboxes › Bypass/Active
Viewing 11 reply threads
    • #195706
      hawkwind65
        For some reason I cannot get my H90 to Bypass/Activate via MIDI command. I’ve done all that’s required in the system, given it a CC#, etc, but it picks and chooses which programs it wants to Activate or Bypass. Can anyone see what must be the obvious thing I’m missing? Thanks.
      • #195707
        joecozzi
          Which act/byp command have you mapped to a CC#? If you map a CC# to P act/byp, sending a value greater than 64 will toggle the active state. Sending a value less than 64 will have no effect. If, however, you map a CC# to P act/byp (M), sending a value greater than 64 will activate, while a value less than 64 will bypass.
        • #195711
          hawkwind65
            Hi…I’ve tried that and it has no effect. I’ve given P Act/Byp (M) a CC#, tried 64 and 65 and the bypassed program will not activate. I’ve programmed my 2 H9’s and they perform flawlessly…the 90…well I just don’t get it.
          • #195712
            joecozzi
              Try sending value zero for bypass and 127 for active on P act/byp (m)
            • #195713
              hawkwind65
                It receives PC’s with no problem at all, but this CC# business it doesn’t seem to want to know. I’m using a BOSS ES8, not that I can imagine the fault is there.
              • #195714
                joecozzi
                  So that I have a reference of what you’re sending, please detail the list of commands you’re sending the H90 from the Boss switcher to try to get it to bypass a program.
                • #195715
                  hawkwind65
                    I’ve now just performed a factory reset and it still does not work!
                  • #195716
                    joecozzi
                      I requested a list of commands. Never suggested a factory reset, but now that the pedal is basically reset, try this:
                      In the system settings > MIDI >  MIDI – Global control, assign a CC# to P act/byp (M).
                      From your Boss switcher, you should be sending that CC# along with a value of zero for bypass or 127 to activate. Make sure you’re sending on the same MIDI channel as the H90, the default is 1.
                    • #195718
                      joecozzi
                        Perhaps this video clarifies things for you: https://youtu.be/tfd3wQHzxcA?t=1026
                      • #195719
                        hawkwind65
                          It appears that you have to have PC at “OFF”, CC# and 63 to bypass, but as soon as you add a preset number it activates regardless of the CC# and value, and I’ve just discovered that by total fluke. Not clear instructions at all.
                        • #195720
                          joecozzi
                            Now that you’ve clarified you’re sending a PC message along with a CC# there is a known issue we are looking to resolve regarding these simultaneous messages. I’m certain it’s a the root of the issue. One option is to recall the program in an already bypassed state if it must start off bypassed.
                            https://www.eventideaudio.com/forums/topic/eventide-h90-midi-pc-change-and-bypass-at-the-same-time/
                          • #195761
                            hawkwind65
                              So I’m realizing that a) you cannot send PC’s and CC’s at the same time, and b) that this has been known for some time. I would have expected more from Eventide, I mean it’s not like these units are cheap! Until this situation is fixed, I have an expensive waste of space on my pedalboard.
