Home Forums Products Stompboxes Bypass/Active Reply To: Bypass/Active
#195716
joecozzi
    I requested a list of commands. Never suggested a factory reset, but now that the pedal is basically reset, try this:
    In the system settings > MIDI >  MIDI – Global control, assign a CC# to P act/byp (M).
    From your Boss switcher, you should be sending that CC# along with a value of zero for bypass or 127 to activate. Make sure you’re sending on the same MIDI channel as the H90, the default is 1.
