Home › Forums › Products › Stompboxes › H9 Harmonizer Gen 2 Questions › Reply To: H9 Harmonizer Gen 2 Questions
June 11, 2026 at 5:35 pm
#195759
There will be Pre/Post (4CM) and Wet/Dry routing modes. The routing is the same as the original H9 if you are familiar with that:
- In Pre/Post, you have a mono Pre path and a mono Post path.
- In Wet/Dry, you have a mono Wet path, and a mono Dry path.
