Home Forums Products Stompboxes H90 Cant PC and Bypass CC together. *BUG* Reply To: H90 Cant PC and Bypass CC together. *BUG*
#195783
eleoh
    Please do. If you could, please escalate this as a high priority bug. I feel like the H90 is being severely limited due to having to choose between PC and CC commands. Getting the H90 back up to MIDI standards would ease a lot of frustration with the device.
    Right now the only workaround is copying a preset and adjusting the parameters, which is a major nuisance as it quickly spirals into being unmanageable and untrackable. I should be able to find a sound I like and tweak the parameters via CC in the same MIDI command. I am using a Quad Cortex and the only MIDI commands I have access to are via scene changes, and this works for everything else in my chain just fine.
    Thank you!
