Home › Forums › Products › Stompboxes › H90 wet/dry control › Reply To: H90 wet/dry control
June 22, 2026 at 9:53 am
#195820
The Program Mix parameter works as following:
- 0-50 will be a constant amount of dry signal, and the wet signal is mixed in as you turn up the knob
- At 50, both the Wet and Dry levels are at the maximum level
- 50-10 will be a constant amount of wet signal, and the dry signal is mixed out as you turn up the knob
It sounds like that is working the way you describe you would like it to work.
If you would like additional control of the wet and dry signals, you could use Kill Dry to completely remove the dry signal. Then the Program Mix will act as a Wet level control. You would need to have an external way to control the level of the Dry signal for this setup.
