H90 wet/dry control
Home › Forums › Products › Stompboxes › H90 wet/dry control
    • #195816
      TOTAL
        Is it possible to assign one control to both wet and dry level?
        What I would ideally like is this:
        0-50 = full dry, wet 0-100
        51-100 = dry 100-0, full wet
        So from 0 to 50 the wet signal would increase while the dry stays present. Then from 50 to 100 the wet would stay at full level while the dry signal fades out.
        If that is not possible as one continuous control, can the full dry / full wet be made, as an option, possible to set on the per-program basis?
      • #195820
          The Program Mix parameter works as following:
          • 0-50 will be a constant amount of dry signal, and the wet signal is mixed in as you turn up the knob
          • At 50, both the Wet and Dry levels are at the maximum level
          • 50-10 will be a constant amount of wet signal, and the dry signal is mixed out as you turn up the knob
          It sounds like that is working the way you describe you would like it to work.
          If you would like additional control of the wet and dry signals, you could use Kill Dry to completely remove the dry signal. Then the Program Mix will act as a Wet level control. You would need to have an external way to control the level of the Dry signal for this setup.
        • #195822
          TOTAL
            That is fabulous thank you for letting me know.
