Home › Forums › Products › Rackmount › using H9000 as an insert compressor via analog DB25 › Reply To: using H9000 as an insert compressor via analog DB25
June 27, 2026 at 2:16 pm
#195950
Both the MOTU 10pre and the H9000 have ADAT I/O. Are you already using them? You could use ADAT for up to 8 channels of send/return (though ADAT on the H9000 only works at 44.1/48 kHz).
