Home › Forums › Products › Rackmount › using H9000 as an insert compressor via analog DB25 › Reply To: using H9000 as an insert compressor via analog DB25 June 29, 2026 at 12:15 pm #195966 wilkinsiParticipant found it. attached. what it does not tell me is whether or not the DB25 snakes will work when combined with an insert cable wired to the requirements of the EMU Protus 2000 Attachments:You must be logged in to view attached files.
