Home › Forums › Products › Stompboxes › H90 help needed with dual mode › Reply To: H90 help needed with dual mode
Hi, ok i will explain my routing in more detail:
The first 11 loops are all mono and connected by send & return from the switcher to the in and output off the pedal.
The overdrive pedal in loop 9 is re-orderd in the switcher after the h90 in loop2 which you can do in the musicomlab switcher without to physically cable them
Routing:
Shure wireless > Wah pedal >Guitar input switcher > Loop 1 cali76 comp. / loop 2 send & ret to H90 input 1 and output 1 / loop3 lightspeed od / loop 4 tumnus od / Loop 5 boost pedal / Loop 6 volume / loop 9 Friedman OD /
Loop 10 EQ2 / Loop 11 Friedman IR-D, i don’t use the mono fx loop of the IR-D by the way…
Then the stereo part start here: as you can see i connected those last pedals in the chain in series to save loops, otherwise i would have to join 2 mono loops to become 1 loop in stereo
Loop 12 send > H9 input
H9 output L & R > H90 input 3 & 4
H90 output 3 & 4 > Big Sky inputs
Big Sky outputs > Nux Looper pedal inputs
Nux looper outputs > loop 12 Return L + Loop 12 Return R
Then finaly :
Switcher LEFT OUT > Radial LEFT INPUT > Radial Thru > Monitor 1
Switcher ISO OUT > Radial RIGHT INPUT > Radial Thru > Monitor 2
This is basically the whole routing and i would really like to use the H90 with all it’s flexibility regarding to routings.
So distortions and pitchshifters in another signalpath then the chorusses and delays.
I want to do this in INSERT MODE of the H90 and use it full potential.
But unfortunately my sound is not great at this moment and there must be a better way to connect it all together, it’s way to noisy with use of distortion and the effects can sound much more clear i believe.
What am i doing wrong? Probably something with the friedman in loop 11 and the connections in the H90 but i am having a hard time solving this properly.
What should I do to get better results ?
Help is appreciated, thanks in advance.
Best regards, Collin
