Home › Forums › Products › Stompboxes › H90 help needed with dual mode › Reply To: H90 help needed with dual mode
Hi, ok i will explain my routing in more detail, i already tried many things and removed the H9 out of the H90, i also altered the cablingmethod and this is what i have right now.
I thinks it’s way better than it was but i just want to make sure i’m not doing anything wrong here.
Part 1: Input & Mono Drives (Loops 1 -10)
Gitaar ➡️ Shure Wireless ➡️ Wah Pedal ➡️ Musicom Lab efx mkVI GUITAR IN.Loop 1: Cali76 Compressor
Loop 2: Free space
Loop 3: Greer Amps Lightspeed
Loop 4: Wampler Tumnus
Loop 5: Boost Pedaal
Loop 6: Volumepedaal
Loop 9: Friedman OD
Loop 10: Source Audio EQ2
Part 2: Loop 11 (Amp & H90 section)
EFX-MKVI Send 11 ➡️ Eventide H90 Input 1
Eventide H90 Output 1 ➡️ Friedman IR-D Guitar Input
Friedman IR-D Main Out ➡️ Eventide H90 Input 3
Eventide H90 Output 3 ➡️ EFX-MKVI Return 11
Part 3: Stereo chain (Loop 12)
EFX-MKVI Send 12 (Mono) ➡️ Eventide H9 Input 1 (Mono)
Eventide H9 Output 1 & 2 (Stereo L/R) ➡️ Strymon BigSky Inputs L/R
Strymon BigSky Outputs L/R ➡️ Nux Looper Inputs L/R
Nux Looper Outputs L/R ➡️ EFX-MKVI Return 12 L & R (Stereo)
Part 4: Outputs to Monitors
EFX-MKVI LEFT OUT ➡️ Radial LEFT INPUT ➡️ Radial Thru ➡️ Monitor A
EFX-MKVI RIGHT OUT ➡️ Radial RIGHT INPUT ➡️ Radial Thru ➡️Monitor C
What do you think?
I believe it’s much better this way but i’m kinda struggling with all the possibilities in routing choices for all these sounds in the H90 and all the options for those sounds.
What is the best routing method for me when i use high gain from my pedal with a taste of chorus out of the H90 for example?
Best regards, Collin
