Home › Forums › Products › Stompboxes › H90 help needed with dual mode › Reply To: H90 help needed with dual mode
July 6, 2026 at 10:48 am
#196023
So now the H90 is connected in TWO loops of the switcher, LOOP 2 mono and LOOP 12 in stereo. Loop 2 is early in the looporder of the switcher and the stereo loop 12 is the last one in the looporder. So when everything works out fine this will probably be the most flexible routing for me right? Regardless of musical taste.
I’ve seen too many different musical tastes represented in setups to disregard it. What you’re suggesting sounds sensible, and will be very flexible, but with a setup this complex everything will depend on *your* taste and *your* goals with the setup.
