Home Forums Products Stompboxes H90 Feature requests Reply To: H90 Feature requests
#196100
drapalik
    Parallel Routing for Insert + Algorithm A, followed by Series Algorithm B
    Hi Eventide Team,
    I am a user of the H90 Harmonizer and I would like to submit a feature request regarding more flexible routing options within a Program.
    Currently, the H90 offers great routing capabilities, but I have hit a limitation with a specific signal chain layout that would be incredibly useful for my workflow.
    The Request:
    I would like to be able to route an external Insert and Algorithm A in parallel, and then route the combined output of this parallel stage in series into Algorithm B.
    This routing would open up amazing sound design possibilities. For example, it would allow us to blend a dry/wet external preamp or a specific drive pedal (via the Insert) completely in parallel with a modulation or delay effect in Slot A (without them affecting each other), and then send that mixed texture together into a global spatial effect like a reverb or delay in Slot B.
    Currently, if we want parallel processing, the global routing forces both Algorithm A and B into parallel, or splits them in a way that doesn’t allow a series effect to catch the combined parallel signal of an Insert and Slot A.
    Adding more granular control over where the Inserts can be placed in the parallel/series matrix would make the H90 even more powerful than it already is.
    Thank you for considering this request and for your continuous support and updates for the H90!
    Best regards,
    Pavol
