Home › Forums › Products › Stompboxes › H90 Feature requests
- This topic has 3 replies, 4 voices, and was last updated 3 months, 3 weeks ago by
drapalik.
February 7, 2023 at 3:35 am #168919
1. Ability to pan individual algorithms/inserts in the routing/insert menu.
This one seems like lowhanging fruit, although I have no idea how easy it actually will be to implement.
2. A simple EQ module that lives in the routing/insert menu in addition to the algorithms and inserts (to clarify i mean that these should be able to run at the same time as two algorithms and inserts are used) . One band with selectable LP/HP/Lowshelf/Highshelf/Peak/Tilt, gain, steepness 6 to 24db (for filters, but would also be nice for shelves and peak) and Q.
This one would be very helpfull in a number of scenarios.
Some examples would be to cut unwanted lowend or highend from pitch effects, Tame or exaggerate resonances, facilitate changing between a single coil and a humbucker guitar without touching your amps settings, midboost for solos, and of course countless other creative possibilities.
Ideally it should be possible to insert at least two of these EQ modules. Four would be great!
I hope the developers will consider this FR.
I believe many people would benefit from these additions.
And thank you for a great product!
February 7, 2023 at 3:37 pm #168934
Thanks for your requests and glad to hear you are enjoying the H90! I have passed these ideas along to the developers.
February 8, 2023 at 3:31 am #168959
Second that! This would be amazing and would save extra pedals.
July 15, 2026 at 6:07 am #196100
Parallel Routing for Insert + Algorithm A, followed by Series Algorithm B
Hi Eventide Team,
I am a user of the H90 Harmonizer and I would like to submit a feature request regarding more flexible routing options within a Program.
Currently, the H90 offers great routing capabilities, but I have hit a limitation with a specific signal chain layout that would be incredibly useful for my workflow.
The Request:
I would like to be able to route an external Insert and Algorithm A in parallel, and then route the combined output of this parallel stage in series into Algorithm B.This routing would open up amazing sound design possibilities. For example, it would allow us to blend a dry/wet external preamp or a specific drive pedal (via the Insert) completely in parallel with a modulation or delay effect in Slot A (without them affecting each other), and then send that mixed texture together into a global spatial effect like a reverb or delay in Slot B.
Currently, if we want parallel processing, the global routing forces both Algorithm A and B into parallel, or splits them in a way that doesn’t allow a series effect to catch the combined parallel signal of an Insert and Slot A.
Adding more granular control over where the Inserts can be placed in the parallel/series matrix would make the H90 even more powerful than it already is.
Thank you for considering this request and for your continuous support and updates for the H90!
Best regards,Pavol
