Home Forums Products Stompboxes H9 GEN2 feature request: Tuner and tap tempo Reply To: H9 GEN2 feature request: Tuner and tap tempo
#196130
davogarcia
    Thank you for your answers.
    Also I noticed in the beta version of Eventide Control that I can connect without problem the first time I boot up the computer (Win10) through the usb cable with the app, but whenever I disconnect the H9 gen2 and try to connect again the same message appears.
    “Connection Error, Error communicating with H90 device may not be ready”, even when it shows as connected in the main screen of the app.
    Sometimes it takes to reboot the computer completely to be connected again to the app. If I delete the pedal in the app and try to add it again it doesn´t show in the Select Port menu.
    Thanks for your help.
