Home › Forums › Products › Stompboxes › H9 GEN2 feature request: Tuner and tap tempo
- This topic has 4 replies, 3 voices, and was last updated 3 hours, 2 minutes ago by
Tourtiere.
July 17, 2026 at 5:16 am #196111
I know the Tuner mode only appears in select mode, but it would be great if you could make it work in whenever mode you were (perfom, presets or parameters) or at least also in perfom mode, if the software design allows it.
Also, if you would keep the light flashing at tempo not only in delay mode (bpm) but also when using modulation effects (when changing Hz) that would be great!
Congrats on an awesome pedal.
July 17, 2026 at 10:29 am #196112
The software design does not allow for accessing the tuner from Perform mode using the footswitches because of how the assignable footswitches work in this mode. Your best option would be using an aux switch or MIDI controller to access the tuner from Perform mode.
The tempo LED will only flash if a footswitch is assigned to “TAP” and tempo mode is on. This will work for all types of effects (modulation / delay / etc). If tempo sync is off, the LED will not flash in time, but that may be something that can change in a future update.
Thanks for taking the time to post here and let me know if you have any other questions!
July 19, 2026 at 5:16 am #196130
Thank you for your answers.
Also I noticed in the beta version of Eventide Control that I can connect without problem the first time I boot up the computer (Win10) through the usb cable with the app, but whenever I disconnect the H9 gen2 and try to connect again the same message appears.
“Connection Error, Error communicating with H90 device may not be ready”, even when it shows as connected in the main screen of the app.
Sometimes it takes to reboot the computer completely to be connected again to the app. If I delete the pedal in the app and try to add it again it doesn´t show in the Select Port menu.
Thanks for your help.
July 19, 2026 at 5:21 am #196131
Well, I have discovered that if you have either close the app before disconnecting the pedal or clicked the disconnect button from the app, that way the app works fine reconnecting again.
October 23, 2026 at 9:50 pm #205901
Hello
Congratulations on the gen 2, truly an amazing creation.
Two queries that are specific to my workflow. Currently there’s an Active/Bypass toggle, as well as a specified “Active” and “Bypass” commands; possible to do something similar with the tuner? So that one incoming external command will decisively turn on the tuner, and another command will turn it off? Toggling can sometimes cause things to get out-of-whack when managing complex presets.
Secondly, and this may have been addressed elsewhere: the PC mapping from the rev 1 has been replaced with CC mapping, which is nice, but is there any possibility the PC mapping could come back in partial form, even if it’s limited to PC 101-127? My reasoning: certain external devices can be programmed to send PC to recall presets, but it gets complicated juggling between PC and CC commands if one wishes to simply bypass a remote H9 unit, or switch it to tuner mode, for example.
