Home › Forums › Products › Stompboxes › H90 routing question. › Reply To: H90 routing question.
I have my input 1 coming from drives output 1 to analog delay and then to buffer/boost pedal. Basically everything in front of the amp. The question would be:
I want to have the possibility to send just my h90 to effects loop while preserving the signal path without changing connections. That would be the set up with my fx loop amp. Just bypassing h90 in the pedalboard while it goes to loop. Of course I would use a couple of cables to go to the loop but pedalboard stays the same. Not that interested in sending program A to the front and program B to loop (pre post setup). Also when I run to an amp without fx loop just to set it up as I have now.
is that possible? What would be the parameters used for that quick change?
