Home Forums Products Stompboxes H90 routing question. Reply To: H90 routing question.
#198169
    Any Programs you create in Insert Mode will need to be exported and reimported to be used in Dual Mode, and vice versa. If you don’t use inserts, you can just keep the pedal in Dual Mode.
    No, the available lists changes when the pedal is changed from Insert to Dual Mode.
