Home › Forums › Products › Stompboxes › H90 Dual Mode DAW › Reply To: H90 Dual Mode DAW
Hi Max,
While I would definitely suggest upgrading to Ableton Live Standard or Suite, there is a way to do something similar using only the Focusrite Control software and Live Lite. In the routing tab in Focusrite Control 2, assign outputs 3&4 to Playback 3-4. Then in Live route the output of your source track to Ext. Out 3&4, then create a second audio track set Ext. In to 5&6 to record the wet H90 signal. There will be some latency with this method, so you would want to monitor through the 18i8, and choose ‘Off’ under the Monitor section on the wet H90 track. You can also use the Track Delay slider in Live to nudge the track around and align it with the source material and the rest of your session. You can also enable Kill Dry in this configuration to record only the wet signal from the H90, and blend the dry signal with the recording after the fact.
