Home › Forums › Products › Stompboxes › Mix Lock on H90 › Reply To: Mix Lock on H90
September 2, 2026 at 7:53 pm
#199602
Actually, there is a wrinkle I didn’t fully consider: which algorithm gets mix locked to 100%. I suppose it would be difficult to globally say both algorithm A and B need to be set to 100%. In parallel routing of algorithm A and B, this may be true. In serial routing, perhaps only 1 of the 2 algorithms would be set to 100% mix.
How do you guys handle this in the H9000 with whatever xx billon number of algorithms it runs? 🙂
