Home › Forums › Products › Stompboxes › Mix Lock on H90
- This topic has 5 replies, 2 voices, and was last updated 1 month, 4 weeks ago by
Gunnmeet.
April 30, 2026 at 1:37 am #195269
Howdy, anyone know if there is a mix lock feature somewhere in the H90? Mix Lock is super handy in Eventide plug-ins when switching between using the plugins as insert effects vs. bus effects. I use my H90 in the same way when switching between recording (bus setup) and in my amp’s effects loop (insert setup). Thanks in advance!
September 2, 2026 at 2:25 am #199532
Bumping this to the top. For now, I’m managing separate lists where I keep mix 100% in 1 list for bus processing. Would still be handy to have a mix lock feature though.
September 2, 2026 at 11:56 am #199576
While there is no Mix Lock feature on the H90, I would recommend using separate lists as you mentioned, or mapping a HotSwitch to toggle between two Mix values. This is an interesting feature request and there’s a chance it could be added in a future update. Do you have any suggestions about how you would like to see this implemented?
September 2, 2026 at 7:27 pm #199601
Thank you for considering this mcasen. The separate list method is working ok but a little cumbersome when I create new patches in one list and then manually copy/edit to another. I had thought about the Hotswitch idea, but it leads to forgetfulness when I have higher mix level programs that I forget to bump up to 100% mix before bus recording (uncovering phasing problems as I listen back later).
I was thinking of having mix lock implemented similarly to global tempo vs. program. Maybe under System -> Preferences as a toggle between Bus Recording (100% Mix Globally Locked) and Effects Loop (use Program-saved mix values).
I don’t know if this would be intuitive for most users though. Maybe others can weigh in?
September 2, 2026 at 7:53 pm #199602
Actually, there is a wrinkle I didn’t fully consider: which algorithm gets mix locked to 100%. I suppose it would be difficult to globally say both algorithm A and B need to be set to 100%. In parallel routing of algorithm A and B, this may be true. In serial routing, perhaps only 1 of the 2 algorithms would be set to 100% mix.
How do you guys handle this in the H9000 with whatever xx billon number of algorithms it runs? 🙂
September 3, 2026 at 10:48 pm #200090
(At the risk of talking to myself) I’ve been thinking about this some more and it would be optimal to have a mix lock option for each algorithm within a program. This way, it’s up to the user to decide if algorithm A or B should be mix-locked while auditioning multiple presets and playing with routing options. The mix lock feature should then logically be in the ‘Presets’ edit mode. Holding down each Quick Knob for a couple seconds would enter mix lock mode to whatever mix values P, A, and B are currently set to. Ok, that’s my $.02. Thanks for considering!
