Home › Forums › Products › Stompboxes › H90 Cant PC and Bypass CC together. *BUG* › Reply To: H90 Cant PC and Bypass CC together. *BUG*
Hi all,
This has been fixed and is currently available for you to test as a public beta release.
To test out the fix:
- Install the latest version of Eventide Control: https://www.eventideaudio.com/software/eventide-control/
- Click the burger icon in top left corner, and select “Settings”
- Check the “show beta releases” option
- Click the cloud icon to view the update menu
- Select the 1.13.2 release, and click update
Once this release is installed, you will be able to send a PC+CC message without needing to program any delay between the two messages. We have tested this with a number of MIDI devices, but there may be differences with how your MIDI device works, so please report any issues you may have.
Note that you must configure your MIDI controller to send the PC message first, followed by the CC, to load the new Program and then adjust the parameters for this to work properly.
If you do experience issues, please email support@eventideaudio.com with details about your MIDI device and how it is programmed and we can help you further there.
Thanks for your patience.
