Home › Forums › Products › Stompboxes › Rose MIDI clock questions › Reply To: Rose MIDI clock questions
#203340
    • MIDI CC 80 determines whether tap tempo effects the delay time or LFO speed
    • MIDI CC 81 is tap tempo
    You should only need to send CC81 with a value of 64 or higher on press to trigger a tap. If that isn’t working, you can try CC81/value 127 on press, CC81/value 0 on release.
