Home › Forums › Products › Stompboxes › H9 GEN2 feature request: Tuner and tap tempo › Reply To: H9 GEN2 feature request: Tuner and tap tempo
#205901
Tourtiere
    Hello
    Congratulations on the gen 2, truly an amazing creation.
    Two queries that are specific to my workflow.  Currently there’s an Active/Bypass toggle, as well as a specified “Active” and “Bypass” commands; possible to do something similar with the tuner?  So that one incoming external command will decisively turn on the tuner, and another command will turn it off?  Toggling can sometimes cause things to get out-of-whack when managing complex presets.
    Secondly, and this may have been addressed elsewhere: the PC mapping from the rev 1 has been replaced with CC mapping, which is nice, but is there any possibility the PC mapping could come back in partial form, even if it’s limited to PC 101-127?  My reasoning: certain external devices can be programmed to send PC to recall presets, but it gets complicated juggling between PC and CC commands if one wishes to simply bypass a remote H9 unit, or switch it to tuner mode, for example.
