Home › Forums › Products › Stompboxes › Wet/Dry or Stereo › Reply To: Wet/Dry or Stereo
October 26, 2026 at 11:16 am
#205976
If you are using the Morningstar ML10X for your signal routing, it sounds like your question for setting up stereo or wet/dry configuration is more appropriate for the Morningstar forum.
Here is a post I found that may be helpful: https://helpdesk.morningstar.io/support/solutions/articles/43000681338-wet-dry-wet-on-the-ml10x
