Wet/Dry or Stereo
Home › Forums › Products › Stompboxes › Wet/Dry or Stereo
    • #205928
      firewolf
        Hi, any one have suggestions on the cabling to run both a wet/dry and a stereo (not at same time) With the Morningstar ml10x, mc6 pro, H-90, two kingsley preamps and two fryette Ps2A
        Thx
        Sam
      • #205976
          If you are using the Morningstar ML10X for your signal routing, it sounds like your question for setting up stereo or wet/dry configuration is more appropriate for the Morningstar forum.
          Here is a post I found that may be helpful: https://helpdesk.morningstar.io/support/solutions/articles/43000681338-wet-dry-wet-on-the-ml10x
