Home › Forums › Products › Stompboxes › Timefactor Issue – Please Help! › Reply To: Timefactor Issue – Please Help!
#206296
pinup57
    Hi there, now that’s a necro-thread! I’m just reviving this topic because so many people experience this and these are still great units: I had mine shelved for over a decade, sometimes I went back at it, opening it up and always got the thing working for an hour and then it did it again. Today I tried on last time, and has en Eureka moment. Yes, it’s the ribbon connection, but not what you think and what I always thought. Here’s the thing:  There’s a sheet of isolating material, looks like metal sandwiched in plastic. That’s the clue: sandwiched. What actually happens is that the ribbon on the upper PCB (closest to the top, so the bottom one when you open it) is soldered directly on the board, and protrude on the solder side. Over time, they will puncture the isolation sheet’s plastic coating, reach the metal inside and create a shortcircuit. I just cut out a piece of rubber (bicycle inner tyre, always keep those!) and putin in between. Boom! Problem gone! FWIW and have a great day, hoping this helps to revive your precious unit as well!
    Greetings from France
    Dirk
