Home › Forums › Products › Stompboxes › Change LFO Destination via MIDI › Reply To: Change LFO Destination via MIDI
#206391
    Strange result.  No Roto Control here, but lots of MIDI control sources.  On a 2nd read, I realized you’re targeting PolySynth (and not the HotSawz or Stutter algos I tested successfully first).
    I’m not seeing that behavior.  I tried both direct CC mapping in Eventide Control, and using Learn on LFO Dest in the H90.  Used the same testing process for the H9 Gen 2.  I set up maximum LFO Amount with a Square waveform for the most contrast, fed by a continuous CC1 message.
    In any case, the LFO Dest moved through selections both visibly & audibly here.  Any chance you can try an alternate MIDI source to the Roto, to eliminate that as a possibility?  It shouldn’t matter, but what CC Number were you using?
