Change LFO Destination via MIDI
Home › Forums › Products › Stompboxes › Change LFO Destination via MIDI
    • #206377
      dknobler
        Hello.
        I have a Roto-Control MIDI unit sending CC messages to the H90, very usefull. HOwever, for synth presets the LFO Dest change over MIDI shows on the H90 screen but doesn’t take effect.
        When I send the CC, the H90’s screen shows the new destination, but the sound doesn’t change: the LFO stays on whatever destination it was already on. Turning the knob on the pedal switches it properly.
        Is this expected, or a bug? Is there a way to change LFO Dest over MIDI?
      • #206391
          Strange result.  No Roto Control here, but lots of MIDI control sources.  On a 2nd read, I realized you’re targeting PolySynth (and not the HotSawz or Stutter algos I tested successfully first).
          I’m not seeing that behavior.  I tried both direct CC mapping in Eventide Control, and using Learn on LFO Dest in the H90.  Used the same testing process for the H9 Gen 2.  I set up maximum LFO Amount with a Square waveform for the most contrast, fed by a continuous CC1 message.
          In any case, the LFO Dest moved through selections both visibly & audibly here.  Any chance you can try an alternate MIDI source to the Roto, to eliminate that as a possibility?  It shouldn’t matter, but what CC Number were you using?
        • #206416
            Can you please try updating your H90 to the public beta release 1.13.2? There was a bug fixed in that version where some parameters would not update correctly when being externally controlled and what you describe sounds like a similar issue.
            In the Eventide Control app, click the burger icon in the top left corner and enable Settings > Show Beta Releases to access the update.
