Home › Forums › Products › Stompboxes › Feature Request / Routing Question: Global Pre-Insert Direct Output on H90 › Reply To: Feature Request / Routing Question: Global Pre-Insert Direct Output on H90
#206531
    There is currently no option to enable this globally, but you can accomplish this using the 2nd insert. You will need to set this up per-Program.
    Note that Insert 2 cannot be routed before Insert 1, so I would suggest you use Insert 2 for the Iridium.
    • Connect Input/Output 4 to the Iridium
    • Connect Output 3 to your tube amp
    • Configure both Inserts to be in the Pre position (see my attached screenshot)
    • Set the Mix of Insert 1 to 50%
    Let me know if you have any questions.
