Home › Forums › Products › Stompboxes › Feature Request / Routing Question: Global Pre-Insert Direct Output on H90 › Reply To: Feature Request / Routing Question: Global Pre-Insert Direct Output on H90
#206533
ercekmert
    Thank you for the detailed suggestion and the screenshot!
    I followed your instructions to utilize Insert 2 for the Iridium and set up the routing per-Program and it worked. In previous routing experiments, I was feeding Output 1 to the Iridium (going into the PA) and Output 2 to my physical stage amp. The main goal of this setup was to run time-based effects after the Iridium while keeping a parallel line for the amp.
    However, I’ve run into a specific operational issue with this current method during live performance scenarios:
    Often, I need to switch instantly from a heavy ambient program (full delay/reverb) to a completely dry tone on the fly. To do this quickly on stage, I usually toggle the Program switch to bypass. But because the Inserts are tied directly to the Program configuration, bypassing Program inadvertently drops the Inserts as well—which takes the Iridium completely out of the signal chain.
    Is there a way to keep the Inserts (specifically Insert 2 for the Iridium) globally active or persistent in the background, even when bypassing or changing program states, so that the core amp-modeling path doesn’t get cut off?
    Thanks again for your continued help!
