Home › Forums › Products › Stompboxes › Feature Request / Routing Question: Global Pre-Insert Direct Output on H90 › Reply To: Feature Request / Routing Question: Global Pre-Insert Direct Output on H90
October 30, 2026 at 12:15 pm
#206540
You’re welcome!
You can set the P Bypass mode to “AB Only” and the inserts will stay active when you bypass the Program.
https://cdn.eventideaudio.com/manuals/h90/1.9.7/content/system-menu/global.html
