10 Function TimeFactor Aux/Midi Control
Home Forums Products Stompboxes 10 Function TimeFactor Aux/Midi Control
Viewing 0 reply threads
    • #107406
      ctc
        I have my TimeFactor mounted on top of my amp so that I can tweak it's knobs on-the-fly from a standing position.
        Since I can't operate the footswitches with my feet, I purchased the recommended FS3X auxiliary switch and Ernie Ball Jr. Expression pedal.
        I would like to select the following 10 TimeFactor functions with my feet: Bank preset 1; bank preset 2; bank up; bank down; toggle mode; repeat on; tap tempo; record; play; and stop.
        The auxiliary switch does most of these functions very well but it can't do bank preset 1 or bank preset 2 without using "alternate mode" which is in itself limiting. It also can't be effectively programed to control more than 6 of these functions at a time.
        I took a quick look at midi, but it seems that the TimeFactor won't allow midi to select bank preset 1 or bank preset 2. Any ideas?
